1994 GMC Jimmy
JOSHUA1977
Electrical problem
1994 GMC Jimmy 6 cyl Two Wheel Drive Automatic
having trouble locating the crankshaft position sensor on my 1994 GMC s15 jimmy
May 29, 2009 at 11:27 AM
  • 75,988 POSTS
I've checked Mit1 ondemand on this vehicle parameter sensors and actuators and there's no listing for crankshaft positioing sensor.
If you're having problems with No spark
Troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
May 29, 2009 at 11:38 AM
