1994 GMC Jimmy
1994 GMC JIMMY
255,000 MILES • 6 CYL • 4WD • AUTOMATIC
THORN321
OK I've had it! Now I have a fuel leak i=on the supply line going to the Injectors. This sucks! Ity is a compressed fitting "threaded" And the other end is is apressed fitting on a flex hose. Can this be cut off and a compression fitting put in its place?
Jan 31, 2010 at 10:09 AM
BLACKOP555
  • 10,386 POSTS
can you get a picture and circle where its leaking?
Jan 31, 2010 at 1:48 PM
