1993 GMC Jimmy Will not stay running
1993 GMC JIMMY
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHONNALYNN31
My blazer just decided one day to sputter till it died like it was out of gas. I have replaced the fuel fliter and fuel pump and new plugs and wires and a gas/injector treatment. It will not stay running. It will fire up then stay running sometimes for a minute or two then sputter and die. I have no idea what is causing this. ; ; i need my vehicle for school. Please help me out.
Sep 12, 2008 at 8:26 PM
ROB2008
  • CAR REPAIR CONTRIBUTOR
  • 258 POSTS
Do you have a check engine light on ? If so go to your local to parts store and get them to put it on a scanner . ( It's usually Free)
Sep 12, 2008 at 8:52 PM
SHONNALYNN31
No, dont have any lights on on the dash. Just keeps sputtering and wont stay running.
Sep 12, 2008 at 8:55 PM
ROB2008
  • 258 POSTS
I would check the
Idle Air Control Valve and
check for vacuum leaks .
Check fuel pressure .
Ensure that the ignition timing is correct .
Sep 12, 2008 at 9:13 PM
SHONNALYNN31
I will give this a try! If this works for me i will be back for a nice donation ^^ Thank you very much!
Sep 12, 2008 at 9:16 PM
