1993 GMC Jimmy Will not start
NICHOLECHEROKEE1969
  • 1993 GMC JIMMY
Engine Mechanical problem
1993 GMC Jimmy 4 cyl Four Wheel Drive Automatic
was running fine. I ran out of gas. When I put more in, it would not start. I replaced the fuel pump, fuel filter and computer. What could it be?
Sunday, June 7th, 2009 AT 3:02 PM
JDL
  • 16,098 POSTS
Hello, my info doesn't show a 4 cylinder? Do you have the spider fuel system or TBI? I'd put a fuel pressure gage on it. You can also check for codes, your obd1, you should be able to check codes, yourself.
Sunday, June 7th, 2009 AT 3:33 PM
