1993 GMC Jimmy Engine won't start
KASILOFB
Engine Performance problem
1993 GMC Jimmy 6 cyl Four Wheel Drive Automatic 97xxx miles
Engine died and would not start. I replaced the fuel pump, and inline fuel filter. Have fuel under pressure to the engine. Replaced the distributer cap, roter, and have good spark to at the plugs. Engine runs while spraying with starting fluid. I am out of ideas.
Thanks for your time,
Bert
Jan 17, 2010 at 3:34 PM
  • 75,988 POSTS
Check the fuel pressure if its within specs and for injection pulses from the injectors
Jan 17, 2010 at 4:19 PM
MILESLEE
[quote:a07a17e710="kasilofb"]Engine Performance problem
Bert[/quote:a07a17e710]
I had to take my jimmy to a mechanic and it was a 200 dollor fix but it had to do somthing with the distributer being bad or a rellay.
Feb 22, 2010 at 8:35 AM
