1992 GMC Jimmy jimmy wont start
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
NEAL9978
quit running one day. fuel running to block but still wont start diagnose the problem please?
Jun 27, 2009 at 6:13 AM
JDL
  • 16,098 POSTS
Hello, not sure if you have TBI or CPI fuel system? If it is TBI, check for an injector spray pattern, the pattern doesn't say much about fuel pressure, but, it should mean there is an rpm signal, at least. Without the rpm signal there may not be any spark at the plugs or injector pulse. With the engine cranking, do you have spark at the plugs?
Jun 27, 2009 at 6:53 AM
