1991 GMC Jimmy Power Windows
150,000 MILES • V8 • 4WD • AUTOMATIC
DRB6903
How can I check to see if the power window motor on the drivers side needs to be repaired. And then how do I remove and replace the motor.
Thank You for your help
Dennis
Jul 27, 2008 at 4:57 AM
MERLIN2021
  • 17,250 POSTS
http://www.2carpros.com/how_to/power_window.htm
Check it out here, when you get the door panel off, check for power at the connector.
Jul 27, 2008 at 5:07 AM
