1991 GMC Jimmy not getting fuel
BIGGUN1974
Engine Mechanical problem
1991 GMC Jimmy 6 cyl Two Wheel Drive Automatic
i am not getting fuel on my 1991 gmc s-15 jimmy
Sep 14, 2008 at 5:57 AM
  • 75,988 POSTS
Do you hear the fuel pump come on for 2secs? If so check the fuel pressure and comeback with the readings this is where we start
Sep 14, 2008 at 6:04 AM
BIGGUN1974
do not here fuel pump run
Sep 14, 2008 at 6:05 AM
  • 75,988 POSTS
Could be the fuel pump fuse/fuel pump relay or just the fuel pump itself has given up-
Sep 14, 2008 at 7:10 AM
RAWR818
Im Having the same problem. Changed the pump, relay and fuses. The fuel pump is only getting 8.5Volts. Im guessing its something electrical but what?
-Raul
Oct 6, 2008 at 7:55 AM
  • 75,988 POSTS
Direct battery power to the fuel pump connector gray wire and see what happens
Oct 6, 2008 at 9:22 AM
RAWR818
[i've treied that, the pump stays on even when the car is off.
Oct 23, 2008 at 5:44 AM
