1991 GMC Jimmy Idling problems
RUNASM64
  • 1991 GMC JIMMY
  • 6 CYL
  • 4WD
  • 150,000 MILES
Is there something that goes with the fuel injectors that makes it run rough? I have ruled out ignition problems. Should I replace the injectors? It is a V6.
Thank you
Saturday, March 20th, 2010 AT 8:33 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. I have to start with the basic questions. How long since a tune-up? Did you use a gage and check fuel pressure? Are there any applicable trouble codes? If you have TBI fuel injection, does the injector/s spray patterns look the same? When you say, run rough, are you talking about Idle? If so maybe idle air system?
Compression good on all cylinders?
Saturday, March 20th, 2010 AT 10:10 AM
