1991 GMC Jimmy brakes and blinkers
1991 GMC JIMMY
OUTLAWRCP
Electrical problem
1991 GMC Jimmy 6 cyl Four Wheel Drive Automatic
it keeps blowing either the 15amp brake fuse or the 15 amp blinker fuse ?? the drivers side brake light and blinker work.. but if i use pass. blinker blows fuse .. if i use brakes blows fuse ?? all bulbs working or new .
Dec 12, 2009 at 1:29 PM
BUDDYCRAIGG
  • 2,262 POSTS
you have a short-to-ground on that side somewhere in the rear.
It could be anyplace between the bulb, all the way up to the turn signal switch.
Dec 12, 2009 at 3:55 PM
