1989 GMC Jimmy engine noise
1989 GMC JIMMY
275,428 MILES • 6 CYL • 4WD • AUTOMATIC
STEPHANELOYER
My 1989 GMC jimmy S-15 makes noise wen i press on the trotle sounds like it needs a valve job but it doesn't do it wen it's in park and just idles .I just got this truck so i dont know is this normal or any suggestion , i saw 2 other truks and they son the same.
Thanks Steph.
Mar 31, 2008 at 11:51 PM
RHALL77
  • 3,361 POSTS
are you sure it is coming from inside the engine? what does it sound like? i would try to remove the belt and listen and see if the noise is still there then you will know for sure if it is internal or not.
Apr 1, 2008 at 12:15 AM
