1988 GMC Jimmy idle erratic in park
166,200 MILES • V8 • 4WD • AUTOMATIC
GMCJIMMY
Rescently had a new long block put in, the idle is searching at idle, my mechanic has put in a tps, iac and a new ecm, no change as of yet, my question is when he checked the iac he told me he had power on only 2 of the 4 wires, thats why he changed the ecm, can you point me in the right direction?
Jan 20, 2008 at 3:56 PM
  • 75,988 POSTS
Have him check the fuel pressure and the EGR system that checks out-look for exhaust restriction.
Did he clean out the throttle body/air bypass passages/throttle plate.
Jan 20, 2008 at 5:23 PM
