1988 GMC Jimmy idle erratic in park
GMCJIMMY
  • 1988 GMC JIMMY
  • V8
  • 4WD
  • 166,200 MILES
Rescently had a new long block put in, the idle is searching at idle, my mechanic has put in a tps, iac and a new ecm, no change as of yet, my question is when he checked the iac he told me he had power on only 2 of the 4 wires, thats why he changed the ecm, can you point me in the right direction?
Sunday, January 20th, 2008 AT 11:56 PM
Have him check the fuel pressure and the EGR system that checks out-look for exhaust restriction.
Did he clean out the throttle body/air bypass passages/throttle plate.
Monday, January 21st, 2008 AT 1:23 AM
