1987 GMC Jimmy where is fuel pump and filter
181,000 MILES • 6 CYL • 4WD • MANUAL
TYLER1986
im not sure where my fuel pump or filter is on my jimmy i know one of them is not working as ny truck will turn over and not start, im getting spark just no gas and i dont know where they are, please help me.
Apr 19, 2009 at 5:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter is under hood, driver side, front engine area, rear of lower radiator hose, mounted in fuel line . Fuel pump is attached to the fuel sending unit, located in the fuel tank. I suggest first inspecting your vehicle's fuel pump relay, located on left front inner fender panel behind A/C compressor relay, before replacing filter and pump..also inspect your fuses.
Thanks for using 2CarPros.com!
Apr 19, 2009 at 5:50 PM
