1987 GMC Jimmy BAD SUN SHELL???
GARYW
Transmission problem
1987 GMC Jimmy 6 cyl All Wheel Drive Automatic
I HAVE A 1987 GMC JIMMY I USE ONLY FOR PLOWING. ONE DAY THE REVERSE WENT OUT, DO YOU THINK IT'S A BAD SUN SHELL?
Jan 9, 2009 at 7:49 AM
BILLYMAC
  • 2,204 POSTS
most likely a reverse clutch pack fried plowing is hard on all trans and typically reverse will go out first. a general overhaul kit should repair the prob. good luck billymac
Jan 12, 2009 at 1:23 AM
