1986 GMC Jimmy vibration
148,000 MILES • V8 • 4WD • AUTOMATIC
EXCALIBUR
after starting my truck, and putting it into drive, there is
when I put my truck into gear and start moving . an overall vibration starts that pretty much vibrates the whole truck. It doesn't feel like a front end out-of-alignment vibration..and it continues when i put it in neutral, and continue moving...its almost like when you go over a road that has grooves cut into it...don't know if that makes sense
Jan 15, 2008 at 6:05 AM
2CARPRO JACK
  • 11,533 POSTS
Check your u-joints. Might have one frozen up causing the bind. Does the vibration change at all with engine rpm?
Jan 15, 2008 at 9:23 AM
EXCALIBUR
In answer to your question, there is no difference when I put the truck , while in motion, in neutral, and rev the engine....
Jan 15, 2008 at 10:55 PM
2CARPRO JACK
  • 11,533 POSTS
Check th eu-joints and have you had the front end inspected?
Jan 15, 2008 at 11:21 PM
