1986 GMC Jimmy Heater Defrost vent
1986 GMC JIMMY
290,000 MILES • V8 • 4WD • AUTOMATIC
FISHERCURTIS
I recently replaced the heater core in my 86 Jiimmy, everything works great! the heat is nice and hot and the fan blows great. But I noticed that when you turn the defrost switch on, the fan still blows nice and hard but it seems the door that opens and closes in the heater module isn't opening..?? and the air just kinda gets blown everywhere and not out the defrost vents where it should. I'm wondering if I hooked those hoses up wrong??(the hoses that are connected to the heater switch) Or does the air valve on the end of the heater module need to be replaced??? I would like to get expert advice before I fool with this again cause it's such a pain pulling that module out, it's also 6.2 Diesel and it has that extra sound deadener in the engine bay, so the either the A/C has to be disconnected or the wheel well needs to come down.. I'm not looking forward to it.
Oct 29, 2010 at 6:37 PM
HMAC300
  • 48,601 POSTS
check to see if you have one of the hoses off. Your motor may not begetting the vacuum it needs to operate. it could be a vacuum hose off anywhere. youshouldn't have to pull the heater down to do that. it should look similar to this
https://images.2carpros.com/forum/automotive_pictures/406719_actuator_7.jpg
Nov 2, 2010 at 10:34 AM
