1980 GMC Jimmy Timing
1980 GMC JIMMY
DTOMLIN
Engine Mechanical problem
1980 GMC Jimmy V8 Two Wheel Drive Automatic
The engine will start but will not idle and cuts off. I discovered that the distributor was lose. I have attempted to reset the timing without much success.
It is possible that the timing belt/chain is the problem? What do I need to do to sovle this problem?
Feb 24, 2009 at 2:09 AM
DAVE H
  • 13,384 POSTS
have the cylinders compression tested !! how have you tried to reset the timing ?
Feb 28, 2009 at 11:49 PM
