no running lights
LESESSLER
I have a 2004 GMC envoy. approx 50000 miles. I have all of my lights except my running lights/low beams. no prob with fuses or bulbs. ?dimmer switch or computer issue and how much should I expect for these repairs? I'm getting desperate and so are the poor souls on the road at night. I just paid $530 for a air solenoid pump and corroided connectnor. what next? HELP!!! damsel in distress with no one to trust. (sorry no donation. I don't have my card with me at work.)
Feb 28, 2007 at 8:50 AM
BHUGG
  • 157 POSTS
Most cars have 2 fuse boxes. If you checked the one in the dash, look under the hood for another fuse box.
We love feedback. Let us know what happens.
Vote for us if you get good answers.
Feb 28, 2007 at 4:49 PM
LESESSLER
I have tried both fuses boxes--the one under the hood and the one under the back seat. I know that this problem is not a fuse or bulb problem. all of this has been checked.
Mar 1, 2007 at 9:05 AM
AVERY
I have a 1990 gmc & if u click on the first notch or 2 of the emergency brake it will shut off your running lights.so check your brake release & if it is disengauged it could be the switch that is attached to the emergency brake pedal
Apr 9, 2007 at 4:12 AM
SASSY2
Try your your relays. We had high beam and no other lights on our 2003 envoy and my husband swapped the relays around and found that the headlamp relay was blown. We had to purchase the relay from gmc dealer. Do you have lights on dim. It could be your DRL relay (Day Running Light relay). Check your owner manual to see which one is required for the DRL.
Nov 1, 2007 at 5:34 AM
BREEDER53
the tail lights don't work but brake lights and other lights do. put in new fuses still no tail lights. Also, dashboard lights are on in the day but not at night. tried all buttons, dimmers, etc.
Jan 13, 2020 at 12:14 PM (Merged)
you need to check for power from the switch to the rear lights. if there is, then you have a wiring issue.
