2006 GMC Envoy check engine light
100,376 MILES • 6 CYL • 4WD • AUTOMATIC
NEWTON1157
Check engine light keeps coming on when I reset the onboard computer with my obd2 car reader it says that my timing over advanced or system proformance (bank1)
the car runs great good on gas and lots of horsepower
Nov 6, 2010 at 5:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
what OBD II trouble code is coming up on the scanner? should be a code like P1234 etc..
Nov 6, 2010 at 6:47 PM
NEWTON1157
[quote:71d6044bf6="bluelightnin6"]what OBD II trouble code is coming up on the scanner? should be a code like P1234 etc..[/quote:71d6044bf6]
the code number that keep coming up is POO14
Nov 7, 2010 at 6:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, there is a technical service bulletin about this issue. A TSB means this is a common problem with the specific make/model but it is NOT paid for by the dealer. The issue lies with the camshaft actuator solenoid which has screens on it that can become damaged and missing. Replacing this solenoid should fix the issue.
Nov 7, 2010 at 12:11 PM
