2005 GMC Envoy headligths
BKHARBUT
Electrical problem
2005 GMC Envoy 4 cyl Four Wheel Drive Automatic 80.000 miles
how to change the head ligths on my Envoy
Nov 5, 2008 at 12:06 AM
  • 110,248 POSTS
Hi:
You will need to open the hood to access the bulb from behind the headlamp assembly. Turn the bulb assembly counterclockwise and it will click. Pull it out, replace bulb, and reverse the order.
Dec 2, 2008 at 9:55 AM
ILLINIJEFF
Actually you have two tabs under your hood attached to your light assy. You pull up on those tabs and the light assy will come out of the front of your car. Go ahead and turn the assy and replace the bulb. Put the housing back in and press back down on the tabs. Your done. Go Air Force!
Dec 4, 2008 at 4:23 AM
