2005 GMC Envoy Engine Pickup and performance lags
SAMEH_166
Engine Performance problem
2005 GMC Envoy 6 cyl All Wheel Drive Automatic 75K miles
For the past 3 months my car has lost its usual pickup. Last month, I changed the oil, oil filter, air filter, but still to no avail there is lag when i push the gas.
However a little improvement was felt when I refilled my gas tank along with these performance solution ( to clearn carburetor engine system etc. ). Once a mechanic told me there is some dirt on spark plugs. though i changed the plugs like only 4 months ago.
I have to travel long distance next week, and am worried about the engine performance.
Any help would be appreciated.
Regards,
Sameh
Aug 7, 2009 at 11:44 PM
  • 110,248 POSTS
Hi:
First, has the check engine light ever come on? Next, has fuel pressure been tested? And finally, a partially plugged caylatic converter will cause a loss of power. At night when the car is hot and running, check the converter to see if it is glowing red hot. IF so, it's plugged.
Here is a how to for checking fuel pump pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Aug 8, 2009 at 1:57 PM
