2005 GMC Envoy Cam Position Sensor
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
RWEAVER0405
My car has been diagnosed to have a bad Cam position sensor. Does anyone know where exactly this is on a 2005 GMC Envoy and how difficult it is to switch out?
Thanks!
Jan 12, 2010 at 10:21 AM
  • 75,988 POSTS
Camshaft Position Sensor
https://images.2carpros.com/forum/automotive_pictures/12900_camshaft1_4.jpg
CAMSHAFT POSITION (CMP) SENSOR REPLACEMENT REMOVAL PROCEDURE
https://images.2carpros.com/forum/automotive_pictures/12900_camshaft2_1.jpg
1.Remove the camshaft position (CMP) sensor electrical connector (1). 2.Remove the CMP sensor retaining bolt. INSTALLATION PROCEDURE
https://images.2carpros.com/forum/automotive_pictures/12900_camshaft3_1.jpg
1.Install the camshaft position (CMP) sensor. NOTE: Refer to Fastener Notice in Service Precautions. Tighten the CMP sensor bolt to 10 N.m (89 lb in) . 2.Install the CMP sensor electrical connector (1).
Jan 12, 2010 at 10:43 AM
