2005 GMC Envoy blower motor
2005 GMC ENVOY
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
RCROSCIOLI
My blower went out on my 2005 GMC Envoy. The heat itself still works but the blower is not functioning. Where do I locate the blower motor and how do I check it to see if it is the blower itself or just a relay or something. It was working for a short time, then stopped, then worked again, and now nothing. Is there there possibly some type of plug or wiring harness that could have come loose?
Jan 5, 2010 at 11:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check your blower motor relay (may be labeled cooling fan relay) located in under hood fuse block.
Jan 10, 2010 at 5:19 AM
