2005 GMC Envoy antifreeze drain plug
2005 GMC ENVOY
MIKE NELUM
Air Conditioning problem
2005 GMC Envoy 6 cyl Four Wheel Drive Automatic
when i run my a/c, i find antifreeze coming out of a small drain hose in my rear passenger wheel well. is this a major concern?
Aug 12, 2010 at 12:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
are you certain it is coolant and not just water? water normally drains from vehicle after A/C has ran, that is normal .
Aug 12, 2010 at 12:52 PM
MIKE NELUM
well i tasted it it smells like antifreeze, it is thinner consistancy it is sweet and pinkish in color.
Aug 12, 2010 at 1:22 PM
BLUELIGHTNIN6
  • 16,542 POSTS
ok since you're certain it's coolant than most likely the heater control valve is leaky and needs replaced.
Aug 12, 2010 at 1:34 PM
