2005 GMC Envoy 2005 GMC Envoy fan noise
GILLAV
Noises problem
2005 GMC Envoy 6 cyl Two Wheel Drive Automatic
My truck have a stronge fan noise and I want to ask you, what I need to check to fix this fan noise? and How Can I fix it ?, Thank You in advance for your response.
May 14, 2009 at 5:46 AM
  • 110,244 POSTS
Does your vehicle have a fan clutch attached to the waterpump or electric fans?
Jul 1, 2009 at 1:51 PM
GILLAV
The fan clutch attached to the waterpump.
I repleaced the fan clutch but the stronge noise continue. I'm thinking is the waterpump, but how can I make sure of this ?, Thank You.
Jul 2, 2009 at 2:14 AM
  • 110,244 POSTS
Usually when a waterpump goes bad, either it will leak coolant from the seap hole, or there will be play in the bearing itself. If you remove the serp belt, check to see if there is any side to side / up and down play from the pulley (which is attached to the pump). Also, with the belt off, check all of the accessories. Spin the alt, waterpump, PS pump... to see if there is any noise. Also, start the engine with the belt off to see if the noise is gone. NOTE: Only allow the engine to run for a few seconds because it will overheat very fast.
Let me know what you find.
Jul 2, 2009 at 5:36 AM
