where is the coolant temp sensor
2004 GMC ENVOY
HOWARDLT
  • 6 POSTS
Engine Cooling problem 6 cyl Two Wheel Drive Automatic 116000 miles
Where is the coolant temp sensor?
Oct 4, 2009 at 8:42 AM
  • 55,423 POSTS
the coolant temperature sensor is located in the engine block by the radiator hose outlet. Here is a guide and a couple of diagrams that shows on both engine for that car. (BELOW)
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Cheers, Ken
May 26, 2017 at 1:02 PM
HOWARDLT
  • 6 POSTS
2004 GMC Envoy 6 cyl Two Wheel Drive Automatic 116000 miles
where is the engine coolant sensor located?
May 26, 2017 at 1:02 PM (Merged)
IMPALASS
  • 3,112 POSTS
Hello –
Should be located on the left front of the engine block, near the alternator – look for a black and yellow wire to the plug.
