Where is the fuel pump located and how much would it normaly cost to replace one?
Mar 29, 2009 at 2:12 PM
OBXAUTOMEDIC
✓Experienced Mechanic
[quote:d3caacdb3e="langforpd"]Engine Mechanical problem
2004 GMC Envoy 6 cyl Two Wheel Drive Automatic 121000 miles
Where is the fuel pump located and how much would it normaly cost to replace one?[/quote:d3caacdb3e]
The fuel pump is located in the gas tank. At a garage it will run about $500 or so.
Mar 29, 2009 at 2:17 PM
The fuel pump is in the fuel tank. Labor rates varies with location could be $70.00-$130.00 an hr. See below quotes
Mar 29, 2009 at 2:21 PM
LANGFORPD
MEMBER
How can you tell if the fuel pump has gone bad? My envoy will crank and idle but when you put it in drive it will only go about 20 feet and spits, sputters and dies.
Mar 29, 2009 at 2:34 PM
You need to stay in one (1) post. You need to check the fuel pressure this is your starting point to rule out the fuel pump. get this done and if okay we'll move somewhere else.
