shuts off while idling
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLMACK
As long as I have my foot on the gas it will continue to run. If I come to a stop, it will stall and shut down. If I turn off the A/C it will start right up
Jun 11, 2010 at 12:30 PM
  • 75,988 POSTS
This is common when you have a vacuum leak or the throttle bore needs to be serviced here are three guides to go over when fixing the problem.
and
https://www.2carpros.com/articles/stall-at-idle
and
Jun 11, 2010 at 12:48 PM
