2004 GMC Envoy 4 WHEEL DRIVE
RENEERECLA
Other Category problem
2004 GMC Envoy Engine Size unknown Four Wheel Drive Automatic 48000 miles
I WENT IN THE DITCH THE OTHER DAY. IT IS STUCK IN 4 WHEEL DRIVE IS IT POSSIBLE THAT IT GOT FULL OF SNOW AND NOW IS FROZEN
Jan 28, 2008 at 5:42 AM
MASTERTECHTIM
  • 4,750 POSTS
DO YOU HEAR A CLICKING NOISE UNDER TRUCK WHEN YOU TRY TO PUT IT IN 2 WD?
Jan 28, 2008 at 5:44 AM
RENEERECLA
[quote:661ecef853="mastertechtim"]DO YOU HEAR A CLICKING NOISE UNDER TRUCK WHEN YOU TRY TO PUT IT IN 2 WD?[/quote:661ecef853]
NO THE LIGHT JUST BLINKS BUT STAYS IN 4 WHEEL DRIVE
Jan 28, 2008 at 5:46 AM
RENEERECLA
NO THE LIGHT BLINKS BUT STAYS IN 4 WHEEL DRIVE
Jan 28, 2008 at 5:51 AM
MASTERTECHTIM
  • 4,750 POSTS
your encoder motor on the side of the transfer case may be frozen but unlikely. try disconnecting battery for 10 minutes to reset the transfer case control module, see if that helps. the encoder motors get full of salt and usually rots out and you have to replace it. hope this helps
Jan 28, 2008 at 5:54 AM
RENEERECLA
I JUST LOOKED UNDER THE HOOD AND THERE IS SNOW UP ISIDE THERE WHERE IS THE TRASFER CASE LOCATED
Jan 28, 2008 at 6:26 AM
MASTERTECHTIM
  • 4,750 POSTS
the rear driveshaft slides into the transfer case in the middle of the truck. the encoder motor is located on the transfer case right behind where the front driveshaft goes into it,.
Jan 28, 2008 at 6:29 AM
