2004 GMC Envoy
FSOMOANO
Electrical problem
2004 GMC Envoy 6 cyl Two Wheel Drive Automatic
The tailgate would not open.
Feb 20, 2010 at 6:16 AM
2CARPRO JACK
  • 11,533 POSTS
You will need to remove the inner trim panel to access the latch assembly to manually work the lock.
Feb 23, 2010 at 8:03 AM
FSOMOANO
How do I remove the inner trim
Feb 23, 2010 at 8:11 AM
2CARPRO JACK
  • 11,533 POSTS
Look for any obvious screws holding it on, if none present it should just pop off.start in the corner and pull it back so you can look behind it to see where the holders are that are keeping it on. then use a flat tool to pop the panel off next to the holders
Feb 23, 2010 at 11:27 PM
