2003 GMC Envoy windshield wiper arms
JEBERLING321
2003 GMC Envoy 6 cyl Four Wheel Drive Automatic 53k miles
Thanks to anyone that can help....I have a 2003 gmc envoy. The springs in the wiper arms have went bad causing the blades to not put the proper pressure on windshield when in use. I have purchased new arms. I removed the bolt that holds the arms on however when I remove the bolts the wiper arms still will not pull off. Is there a secondary clip holding these on or is there a special trick to pulling these off? I have tried using some leverage inderneath the arm to release them and they still will not budge. Any help would be greatly appreciated.
Jim
Mar 7, 2010 at 5:43 AM
HMAC300
  • 48,601 POSTS
spray some penterating oil after you take the bolt out. then take a larger screwdriver and protect the paint, pry up on the arm on both sides if you can. it should popl off then.
Apr 2, 2010 at 1:33 PM
