2003 GMC Envoy Shift indicator
88,500 MILES • 6 CYL • 4WD • AUTOMATIC
JUDDSTER8260
When I put my truck into D for Drive, sometimes the light bar under the D doesn't light. The same with P for Park. Thus, it doesn't allow the lock/unlock for the doors to activate. Any ideas?
Jan 21, 2009 at 10:42 PM
MMPRINCE4000
  • 8,548 POSTS
You will most likely have to remove floor console and check switch. It may be loose or bad and/or the shift cable has come loose from housing or at trans. connection.
Jan 22, 2009 at 1:58 AM
