2003 GMC Envoy Power Windows
128,000 MILES • 6 CYL • 4WD • AUTOMATIC
SJDEFRANCESCO
The power window on the passenger side will go 'down' but many times fails to go 'up.' Since the motor operates in the downward direction, I suspect the problem resides in the switch. The same problem occurs whether using the dirver's or passengers side window control switch.
The mechanic wants to replace the motor and regulator which increases the repair significantly. I am told that the motor has drawn enough current to damage the switch and all needs to be replaced.
I noted that the circuit is fused and any overload condition is mitigated by a blown fuse.
He agreed to replace the switch, but warned me of future problems. What are you thoughts?
Sep 30, 2010 at 8:40 AM
SATURNTECH9
  • 30,868 POSTS
It sound's like a bad window motor you would have to see if you had power and ground to the window motor when the window wasn't going up.If that was the case i would replace the motor or motor regulator and hold off on replacing the switch.
Sep 30, 2010 at 9:02 AM
SJDEFRANCESCO
Saturn Tech - thanks for your reply.
Since the motor operates with out issue on the 'down' direction indicates to me that the motor is in good working condition. The problem is that it does not operate in the 'up' direction.
The switches function is to reverse polarity to change the directinon of the motor (window). Since this is not occuring, leads me to believe it the problem is in the switch (or contact).
Sep 30, 2010 at 9:14 AM
SATURNTECH9
  • 30,868 POSTS
Here's the problem it take's more force to raise the window then to make it go down.So if you have a weak window motor or it's drawing to much power to make it go up it's thermal breaker in the motor will kick out.The thermal breaker is what shuts the power off to the motor when it reaches full up or down position.Unless you checked to see if you have power and ground to the motor when it doesn't go up your just guessing as to what is really wrong with the window.So if you want to guess the switch then good luck too you but if you guess wrong your going to be paying more because then you just bought a switch and now you will being paying for the window motor/regulator.I gave you my best advice do with it what you want.
Sep 30, 2010 at 9:26 AM
