2003 GMC Envoy Noises
RUSS-99
Noises problem
2003 GMC Envoy 6 cyl Four Wheel Drive Automatic
What you cause a humming noise that is coming from
the Rear End or somewhere in that area.
It does it when I step on the gas.?
It is not loud and the car runs Ok...it just has this
noticeable noise.?
Can't say for sure where it is going from?
Thanks
Feb 18, 2010 at 6:57 AM
DOCFIXIT
  • 18,828 POSTS
Will it make hum in park by steping on gas? if yes have helper work gas listen at fuel tank hum from there? if yes then fuel pump
Feb 18, 2010 at 7:06 AM
