stuck in park
2003 GMC ENVOY
KENDABU
Electrical problem 6 cyl Four Wheel Drive Automatic 170,00 miles
Recently i had my car towed to dealer because my car wouldn't start i replaced the fuel pump, after car was towed back to me dealer says they had a hard time getting my car to shift from park. They looked into it and it came out of park. Lately it is random my car will get stuck in park and sometimes it will work. I took it to mechanic and they said it could be neutral switch and they replaced it the gear shift is working but I'm concerned was this the right thing to do?
Jun 19, 2010 at 2:26 AM
  • 55,267 POSTS
What happen is the interlock solenoid becomes weak and doesn't lift the lock from the gear selector. This can be checked with a test light and if the unit is getting power but not working it needs to be replaced.
Here is a guide that will help us get the problem fixed.
I have seen where the sifter cable becomes difficult to move causing a problem as well.
Please let us know what you find.
Cheers, Ken
Sep 11, 2017 at 10:26 AM
MAMICHULA
the shifter button will not push in to allow you to shift out of park
Sep 11, 2017 at 10:26 AM (Merged)
Check the brake lights if its functioning properly if okay -check the shift interlock control solenoid
COYLELISTIE
Today when I went to start my car, it hesitated.. Now, it won't start at all. My gauges go crazy when i'm trying to start it, It also won't go out of park.. Sometimes, it tries to start, other times it does nothing at all.
start with having the battery checked. it sounds like low voltage
COYLELISTIE
The battery was checked and is fine. My husband was thinking it might be the ignition switch.
LOUIEMCGOON
has a problem with the Automatic Tranmission Gear that's stuck on Park. What could have cause it to get stuck? I drive a GMC 2004 Envoy XUV. I got stuck in traffic when I changed the gear to Park but when I tried to change back to drive it wouldn't go at all, not even the button on the side of the gear. Funny thing, the lights in the Control is in Neutral. Any thoughts on what maybe the problem?
Sep 11, 2017 at 10:27 AM (Merged)
Check if the brake lights are working if so-have the shift interlock control solenoid -checked-
