2003 GMC Envoy code p0172
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
BUCKSFAN
Is this an injector problem, I also have a p0340 which talks about a sensor.
Jul 15, 2009 at 12:48 PM
  • 75,988 POSTS
Rich running condition could be caused by the following:
Bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Jul 15, 2009 at 12:59 PM
