2003 GMC Envoy code P0172
BUCKSFAN
  • 2003 GMC ENVOY
  • 6 CYL
  • 4WD
  • 90,000 MILES
Is this an injector problem, I also have a p0340 which talks about a sensor.
Wednesday, July 15th, 2009 AT 7:48 PM
2003 GMC Envoy code p0172
Rich running condition could be caused by the following:
Bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Wednesday, July 15th, 2009 AT 7:59 PM
