2003 GMC Envoy
2003 GMC ENVOY
KRISTA34
Engine Mechanical problem
2003 GMC Envoy V8 Four Wheel Drive Automatic
in the past week my truck has had problems starting (probavly has happened 5-6 times)when i turn over the ignition onlt the dash/lights come on then nothing else happens if i try it again, absolutely nothing!if i let it sit for 10 minutes or so it uaually starts up. what's going on?I was told maybe the safety neutral switch.
Apr 22, 2008 at 11:34 PM
SERVICE WRITER
  • 9,123 POSTS
Try to shift it into nuetral next time and see if it starts that way.
How are the headlights when it doesn't start, bright or dim?
Do the lights dim when you try to crank it?
Apr 22, 2008 at 11:42 PM
