2002 GMC Envoy No Reverse Whine
ASA
I have a 2002 GMC Envoy SLT 4WD, It has a 4.2 liter in line six cyl engine with approx 70,000 miles on it. The transmission is making a load whining noise in park and nutrel and reverse and some low whine noise in other gears. It will pull in drive and 3rd and low but it does nothing in reverse except make a load whine noise. The filte and fluid has been serviced about 20,000 miles back.What do you think the problem is???
Nov 15, 2007 at 8:53 AM
  • 75,988 POSTS
Internal defects within tranny. Have it pressure tested to identify the problem.
Scanned the computer for code/s.
Nov 15, 2007 at 11:06 AM
Suggested Repair
Have the transmission pressure tested and scan the computer for codes to identify internal transmission defects causing no reverse and the whining noise.
Conversation Summary
The owner of a 2002 GMC Envoy SLT 4WD with about 70,000 miles reports a loud transmission whine in park, neutral, and reverse, a lighter whine in other gears, and no movement in reverse. Drive, third, and low still pull, and the filter and fluid were serviced about 20,000 miles earlier. The expert attributes the symptoms to internal transmission defects and recommends a pressure test and a computer code scan.
