2002 GMC Envoy power steering failure
125,010 MILES • 6 CYL • 4WD • AUTOMATIC
PAUL PANZEGRAU
power steering very hard to turn
Dec 22, 2008 at 4:13 AM
MMPRINCE4000
  • 8,548 POSTS
Check fluid level in PS pump resevour, if OK, then check for leaks in pressure and return lines.
Generally the PS pump will make a whining noise if low.
If no leaks and fluid level is good, I would check outer tie rods. Raise car put on stands and see if wheel is hard to turn, if so, you may be looking at a rack problem, tie rods, ball joints, OR booster vacuum leak, leaking diaphram. To check diaphram, hook up vacuum gauge pump and see if it holds vacuum.
Jan 1, 2009 at 10:31 PM
