2002 GMC Envoy fan blade running extremely fast
2002 GMC ENVOY
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
MGADOW
Monday my Envoy started making a strange sound. It sounded like a jet plane taking off. When stepping on the gas the car would not excelerate like it should the rpm's were around 2.5 to 3 and the car was only going about 35 to 40. I checked the transmission fluid and valve which it needed a quart of fluid and we put cleaner on the vavle because it was a little sticky. This did not work. We thought then that it might be the fan clutch because when the belt and fan are off the car it idles and sounds normal. My question is what else could it be? The fan clutch seems to be ok.
Dec 3, 2008 at 6:30 AM
MMPRINCE4000
  • 8,548 POSTS
GM had some problems with the fan clutch on Envoys. They would make a high pitch whine or knocking.
Contact GM about this and see if it a free replacement.
Dec 13, 2008 at 10:20 PM
GILLAV
Please, if you found the solution, please share with me, because I have the same problem. I repleaced the fan clutch but the sounded like a jet plane continue. I will be check the water pump or the alternator.
May 26, 2009 at 5:21 AM
