Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Envoy
Engine
Computer
Limp Mode - Reduced Power
2002 GMC Envoy check engine light reduce engine power
2002 GMC ENVOY
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
MAGVIEW
MEMBER
1 POST
Reduce engine power . what this mean?
Aug 28, 2008 at 10:06 AM
MMPRINCE4000
Experienced Mechanic
Have the PCM scanned at most autoparts stores for free.
It could simply be a sensor bad that is causing it to run rich, or a low coolant level. The scan should tell you what the problem is.
Oct 21, 2008 at 12:23 AM
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
