2002 GMC Envoy Check Engine light on
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
AGARDNER1
Hello, there are two codes that were listed from my diagnostic test, (P1482) Manufacturer control Auxiliary emission controls), (P1271) Manufacturer Control Fuel Air Metering.) Please help with any info on what repairs I would need. Thank You!
Feb 8, 2010 at 9:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P1271 : Excessive Difference Between Accelerator Pedal Position Sensors
Check wiring at both APP sensors and test both sensors.
DTC P1482 : Cooling Fan Clutch Control Circuit Improper Voltage
Are your cooling fan(s) operating normally? If not check cooling fan relays
Feb 8, 2010 at 9:40 AM
AGARDNER1
[quote:871a50faf3="bluelightnin6"]DTC P1271 : Excessive Difference Between Accelerator Pedal Position Sensors
Are your cooling fan(s) operating normally? If not check cooling fan relays[/quote:871a50faf3]
Feb 11, 2010 at 4:47 AM
