2002 GMC Envoy 4 wheel drive
2002 GMC ENVOY
61,000 MILES • 6 CYL • 4WD • AUTOMATIC
LVERT
My 2002 envoy fails to shift into 4 wheel drive.
Jun 4, 2010 at 9:16 PM
BMRFIXIT
  • 19,053 POSTS
many things to consider
check fuse 1st
have to scan for codes
ARTICLE BEGINNING
Condition
Some customers may comment that the 4WD/AWD indicator lights on the selector switch do not work, or the 4WD/AWD system may be inoperative and/or the service 4WD light is illuminated. The condition is typically intermittent and always occurs at key-up. Upon investigation, the technician may find DTC C0550 set.
Cause
The Transfer Case Control Module (TCCM) has not received the wake-up call during key-up and has remained in the "sleep mode".
When the TCCM is in the "sleep mode", it will not communicate with the class II bus or the Tech 2(R).
Correction
Try to communicate with the TCCM. If no communication, go to step 2. If communication is possible, go to step 5.
Remove the underhood (ATCM or TREC) TCCM fuse.
Wait 30 seconds.
Reinstall the fuse. The module should "wake up" and communicate with the Tech 2(R).
Check for codes in the TCCM. If a C0550 is found current or in history with or without other codes, replace the module and go to step 6.
Reprogram the TCCM with the latest TIS software using normal SPS procedures.
Verify operation and that no codes are present.
IMPORTANT:For the 2002 model year, the TCCM must be replaced and reprogrammed
Jun 4, 2010 at 10:58 PM
