2002 GMC Envoy 2002 Envoy - 4 Wheel drive Binding / Rubbing
2002 GMC ENVOY
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROBBY31
When I put my 2002 GMC Envoy into 4 wheel high and it gets warmed up, when turning right or left, the right front sounds like it is binding up. This will continue until i take out it out of 4 wheel high. When the vehicle stops, and i take it out of 4 wheel high, i can hear the electronic hub on the right side let loose, while standing still. It's like it was tight, when turned off it took off the pressure. What could possible be wrong? I took to the dealer, and their first option was to replace all of my fluids, which did not fix my problem.
Oct 20, 2008 at 1:36 AM
DENNYP
  • 1,824 POSTS
Is this happening when you are on a hard surface such as asphalt or concrete, or is it when you are in mud or snow?
Oct 26, 2008 at 12:04 PM
