2000 GMC Envoy Intermittent operation on all windows
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
MKYLMAMAA
My power windows sometimes stop working for a few seconds, and if I try pressing the controls they don't respond. However if I wait for 5-10 seconds and try again, it works. This seems to be a problem with *all* the windows in the car, and happens with all the controls including driver side master controls for all windows. Is there a common part that could be at fault?
Apr 14, 2009 at 4:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First you need to use test light and check master switch . If wiring is OK then suspect faulty master switch.
Thanks for using 2CarPros.com!
Apr 14, 2009 at 6:46 PM
