1995 GMC Envoy not going into 4 wheel drive
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
WOOD01FISH
tranny only stays in 2 wheel high
when selecter is turned to any position nothing happens. also light on selecter not working
Nov 25, 2008 at 3:23 AM
  • 110,248 POSTS
Hi:
If the 4x4 unit will not engauge, you problem most likely lies with the actuator located on the transfer case. Check it for power when shifting from 2 to 4 wheel drive. If you're getting power, the actuator needs replaced.
Let me know what you find.
Dec 2, 2008 at 9:42 AM
