2005 GMC Canyon truck will not idle...
2005 GMC CANYON
ASW73
Engine Performance problem
2005 GMC Canyon Four Wheel Drive Automatic 63000 miles
my truck will not idle properly. It just started doing this tonight. when I start it, my rpms usually idle smoothly @ 500-600 but tonight it kept jumping and dropping so low that it woul die. when I could keep it running long enough to drive it rsn pretty smooth until I had to stop and as soon as I would brake, the engine would try to die and my lights would dim a little, and if it did die it was hard to start back ( 2-3 tries)
Dec 7, 2008 at 10:20 PM
Lets get the idle air control valve and throttle position sensor check out and then report back for more-also to include the PCV and EGR valves-
Dec 7, 2008 at 10:38 PM
