2005 GMC Canyon Rough idle
2005 GMC CANYON
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
CMLIVINGSTON
My 2005 GMC Canyon has a check engine light on I have had the computer scanned and it said that it was the idier control box. I took it off and cleaned it but it didnt change still idles rough and check engine light is still on. It also shifts hard into 2nd gear when accelerating slowly it wont do it when accelerating quickly. PLZ help!!
Oct 1, 2010 at 10:59 AM
I took it off and cleaned it but it didnt change still idles rough and check engine light is still on. Is it for the same code if so is the IACV functioning properly? If not replace it-also might want to test the throttle position sensor and vehicle speed sensor for the shifting problem
Check the tranny fluid condition and level
Oct 1, 2010 at 11:27 AM
